![]() | Home > Maintenance & Modifications > Compomotive's new PD1880 18" wheels |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
So you are going to take it off road then Tim? |
Ali, I'm looking for a set of winter tyres and wheels - I have now got a set of 19" wheels thanks to Salmon Fisher.
The tyre fitters checked the arches for the MT/Rs touching as it looks close when at access hight.
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Tim any pic's of the wheels ? RRS TDV6 Gone but still around
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Howdy Jay, there is a thread on rr.net about this wheel. They charge US$426 each here in the US, not bad considering the current exchange rate and transportation costs across the pond:
Here's a direct link to the piccy just for Jay
Like those! |
Nice and simple and should be easy to clean the mud out of them after a play off road! I don't know how well the white or gold coloured sets will stand up to off-roading though |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 ![]() ![]() |
Tim, can you confirm that the old style 19 inch wheel will also clear the Brombos on a TDV8? SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD 2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys |
I'm not Tim |
Yeah I am aware about that Shmoogle, but I am in the process of ordering a TDV8 and the dealer is very firm about the fact that the old style 19 inch wheel does not clear the Brembos. I am asking cause the TDV8 comes with the 20" wheels and I'd like to keep my 2005 19 inch alloys for winter and offroad tyres. SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
Novice question ![]() ![]() TDV8 - gone Audi Q5 3.0 Tdi Sline wef 6/11/10 |
When the RRS first came out in 2005, a few units were apparently fitted with 8x19 wheels. The 8" width was not sufficient to clear the Brembo calipers. Shortly thereafter, the same mold was "stretched" to 9" wide to fit the Brembos. Unless you read the specs on the alloy (I think it's stamped or printed inside one of the spokes) or physically measure it, it's impossible to tell the difference between the two wheels by looks alone. The mildly redesigned 19" rim on 2007+ models should also be compatible with the bigger front brakes. In the US, I don't think we ever got those "skinny" 19s, but some early production models in Europe may have them. The door tag on my NA-spec HSE actually lists them both: 8.0x19 and 9.0x19. If you own a MY05 or early 06, your dealer may have a point. ![]() |
The tyre size will compensate for that... If you pick the correct tyre size. ![]() A tire calculator helps if you are comparing different size wheels: http://www.discounttire.com/dtcs/infoTireMath.dos ![]() |
