Home > General > Clock & info button problems
acucobol
Hi
This morning I started on my morning commute to work and notised the clock kept saying 7:03. Had the car in cruise control mode and pressed the button to reduce the maintained gap, but no graphic was displayed. Tried pressing the info button on the stalk but again the information did not change.
Is this a simple unplug and plug back in fuse job or a take back to dealer one? If it is the former any ideas on which one to fiddle with?
Thanks
Post #140653 Mon Oct 08 2007 7:42am
Try a soft reset. Using the key fob press lock, unlock. lock and unlock then start the car. If that hasn't sorted it call LR assist. 2005 Zambezi TDV6 - Gone but not forgotten
Post #140654 Mon Oct 08 2007 7:47am
acucobol
Worked a treat!
Thanks
Post #140656 Mon Oct 08 2007 8:14am
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Same issue this morning! Will try the trick tonight.
And I actually thought I was going to be early for work!!! Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #165847 Thu Apr 17 2008 12:48pm
