Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
GazP Member Since: 06 Apr 2013 Location: Stevenage Posts: 29 |
I have a knock which fits this description but two different specialists have told me that is is just the anti roll bar bushes... i say just despite hearing they both need 2 to 4 hours to fit new ones ...perhaps I'm a bit new to the RRS to be able to tell the difference myself |
Thu Apr 11 2013 8:21pm |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
Mine has CLONKED since 3000 miles. Cannot be bothered to even ask LR to look at it. Now done 50k and still CLONKS Are you telling me the ALL NEW RRS 2014 @ £87.000 (with toys I would like) will still CLONK ? SDV8 vogue SE. Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
Tue Jul 09 2013 10:32pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Just had my rumbling front suspension sorted - new ARB bushes and modified mounting bracket. Silence has been restored. FF 4.4 V8 Soooo looking forward to this bad boy
Wed Jul 10 2013 7:29am |
YES GOOD.
Wed Jul 10 2013 9:46pm |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
(repost) one mechanic that inspected my car and recommended changing front ARB bushes, also said they would remove two components that contribute to the noise and actually serve no purpose. in fact Land Rover recommend these are removed. does anyone know what he was referring to. he did tell me but it escapes me now (there were so many problems we discussed with the car, ive forgotten what this was) 07 TDV8 + BAS map |
Tue Aug 06 2013 12:50am |
Ben1975 Member Since: 21 Sep 2012 Location: Aylesbury Posts: 5 |
So last year I had a TDV8 (09) and then a supercharger (59)... both knocked and rattled so I gave up and flogged them both.... Have just bought a 12 plate supercharger and it's brilliant. Totally silent, drives in a straight line. Land Rover made a few changes over the years, the most significant being the modified ARB compressor from a different supplier. It can be retro-fitted, but it's the most expensive option.
Mon Sep 02 2013 8:10pm |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
Guys, I may have posted this in the maintenance section also but can I pick your brains?
Sat Oct 19 2013 4:10pm |
LEESY Member Since: 25 Mar 2010 Location: Manchester Posts: 14 |
" new ARB bushes and modified mounting bracket."
Mon Oct 28 2013 4:54pm |
I guess it would be a Google job for LR parts suppliers.
Mon Oct 28 2013 4:59pm |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
So before I go and buy one of these - is it hit and miss that you get a crappy one? Is there something you can ask the owner for before making the deal - or is it that they just go and you are stuck with it. |
Wed Feb 05 2014 9:39pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8851 |
Test drive it over a broken surface. You'll know if the bushes need doing - it's a very obvious noise.
Thu Feb 06 2014 12:56am |
Cool - testing on the weekend with one. Looks lovely but I hear dealers do them up to look better to bling you to sale! |
Thu Feb 06 2014 12:05pm |
mcdziubek Member Since: 14 Aug 2014 Location: Cippenham Posts: 3 |
Is this knocking is so bad that the car can't be used or it is just annoying clonk every time you turm steering wheel? Does the knock stops when at motorway speed? |
Fri Aug 15 2014 3:49pm |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 |
The items to remove are the front body to chassis dampers mounted at the back of the front wheel arches and hidden by the wheel arch liners. They do not actually contribute to the noise but they do act as one of two noise transmission paths to the cabin. (The other path is via the No. 2 body mounts) PS Only just realised that the original post is over a year old - still the info might still help someone. |
Sat Aug 16 2014 9:49pm |
