![]() | Home > General > Range Rover Sport - Underbody Corrosion |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Town & County (Aberdeen) LR Dealer has eventually called me back to advise that Land Rover will send an engineer to inspect my car prior to any warranty work. This may take some time but will get done, they say. The dealer stated that the car was a bit of a mess and asked if my car has been used in the sea (i.e. towing yachts / boats etc) - previous owner used the vehicle on motorway etc only.
The doc Member Since: 31 Oct 2006 Posts: 1173 ![]() ![]() |
iwantone Member Since: 05 Jul 2006 Location: UK Posts: 42 ![]() |
I would say that a warranty exclusion for salt corrosion is unreasonable under the Unfair Contract Terms Act 1977 since (a) the UK salts its roads; and (b) LR sells its cars on the basis of off roading and ruggedness. It simply won't play well in the press for this exclusion to be enforced. |
chaps, still no news from LR.
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 ![]() ![]() ![]() |
Guys,
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
I have a D3 ( basically the same underneath), of about the same age, the corrosion on exhaust system is unsightly but pretty normal for a UK based car I would say. Mine has rust on the chassis like yours where the (very thin black) paint had been scuffed during build, mind you the chassis is made of pretty hefty gauge steel and would more than likely outlast the rest of the car, even if rusty. I sprayed waxoil on and inside chassis rails to try to stop it getting worse. I would be more concerned about the corrosion on some of the steering / suspension components shown on your pics. I think you are correct to bring this to the attention of LR,as it does seem to be worse than most, but salt in any quantity will not help, yours may have been driven on salty roads by the previous owner and never ever hosed off underneath from day one. I wouldn't get anything treated until LR have inspected it / made a decision on it,because it may make the corrosion less noticeable with waxoil or whatever all over the things than can be treated. Good Luck any way. |
thanks texstar. still waiting.......... LR Aberdeen (Town and County) have been chased up but "HAVE BEEN ON HOLIDAY"..... Fu ![]() ![]() |
I bet if you went to buy a car or have one serviced over the last 3 weeks they would not have been on holiday! |
Update
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
You want the problem fixing don't you though not hiding - I agree exhausts are likely to rust and would consider them a consumable but the structure and key components should be mint before being protected otherwise they'll rust away out of sight - I appreciate the waxoil will slow it but nevertheless.... |
rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551 ![]() ![]() ![]() |
Maybe a token action to get the car through the manufacturer's three year warranty! On the other hand what other alternative action could they take? Personally, I would want to inspect the underside of the car after derusting and prior to waxoyl treatment to ensure the rust removal had been done properly. |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 ![]() ![]() ![]() |
There is another option Jo |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 ![]() ![]() |
I know the one you mean Envoy, they advertise in the LR mags don't they?
davidbrown Member Since: 08 Aug 2007 Location: Beside my dream Rover Posts: 11 ![]() ![]() |
replace the badly corroded parts then have it undercoated for protection |
