![]() | Home > Maintenance & Modifications > 18" RIMS ON S/C (Long Awaited!!) |
andrewjakovac Member Since: 11 Sep 2006 Location: Australia Posts: 32 ![]() ![]() ![]() |
So I searched and searched for a way to get anything smaller than a 19" rim on my Supercharged Sport (07), and finally my local offroad wheel & tyre ledgend found some for me. After about 101 visits to rim shops who think they all have the answers.. Until they see the size of the rotors & calipers of course..!!
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Your going to slow |
By the sound of that music it seems you had Rolf Harris in the back of the RRS! 2005 Zambezi TDV6 - Gone but not forgotten
Yeah, too slow to get my will written in time... pretty scary when you are going sideways and trees are skating towards you |
chex Member Since: 06 Mar 2006 Location: UK Posts: 210 ![]() |
ROFLHARRIS |
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 ![]() ![]() |
Looks like a quiet amble on a picnic trip |
The rolling circumference is the same as the original 20"s, so the speedo is the same.. good point though.. |
Ok, here’s a slap happy explanation of the specs and details involved in putting 18” rims on a RRS S/C (only.. i.e. if you have the factory front Brembo’s)
Uploading images
Thanks for that info about uploading images...
Hope the information has helped so far..
drevs Member Since: 04 Sep 2006 Location: USA Posts: 43 ![]() ![]() |
Definitely, thanks for posting. You should be able to go a bit bigger than 255/55-18, however your truck will seem a bit slower and your speedo will be pessimistic. Apparently you can go all the way up to a 285/60-18. Check it out: http://www.rangerovers.net/outfitting/tires/sporttires.html Did you ever try an LR3 18" wheel like this: ![]() Those would make a conversion super easy since the offset and bolt pattern are already machined correctly. Regardless, be sure to post the offset information when you find out. Did you consider just removing those little caliper 'vibration damping' blocks altogether? From my relatively layman perspective, it seems that LR underengineers some parts of the truck. They then compensate by adding weight, or 'balancers'. For example, the swinging concrete blocks just inside the rear bumper. As if the truck needed to be ever MORE obese! ![]() Maybe you could get away with removing those balancers altogether... |
Hi Drevs,
I have not tried an LR3 wheel... just a thought.
