Home > General > Locking wheel nut removal
Motorman
United Kingdom 2007 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Oh the joys
Had the beast for about six months.
Thought it was time to sort out the park brake and ride height issues
Some clown had air gunned the wheel nuts back on.
Had to dig off the steel caps to get to the bolt.
Look at the photo of the length of bar I had to use
Same problem with locking wheel nut, the major problem is its now turning pretty freely and I suspect the stud is rotating on the hub
Is it as dire as that and looks like wrecking an alloy to get access
Thanks for your help
Post #641570 Sun Apr 28 2024 12:10pm
Maybe same as yours
?si=4WobKC9zM-YS_-Ix
Post #641575 Sun Apr 28 2024 3:31pm
Motorman
Many thanks for that spot on by the looks of it
Will keep you posted on progress
Ive got a mig welder might try cutting through and welding them both together
Post #641579 Sun Apr 28 2024 5:13pm
gogsy1956
Had the same issue with mine, the cap is hardened steel but if you can get a hole in it,, as big as possible and a nice sharp cold chisel it will break leaving the stub,, then you can weld something suitable on. A bit patience and it will come,, better than trashing a wheel. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #641580 Sun Apr 28 2024 6:30pm
