Home > Wheels & Tyres > no spare!! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4853 |
Not sure I would bother with cost of a Run-flat for something hopefully you will never use, considering they often get nicked which is why you might not have a spare, unless of course the rest of the car has them fitted, just get a full size spare wheel/tyre of the likes of e-bay. Not sure what a BT94 is don't think it is a L/R number, if you add a picture of the wheel someone should be able to identify it for you.
Sun Apr 21 2024 12:33am |
upbeat Member Since: 10 Feb 2024 Location: Bury Posts: 23 |
Thanks , I think it may have been stolen as the cable has been cut , so need a new winch either way!
Sun Apr 21 2024 2:36am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Unless you buy a new one, the space saver you buy online could well itself be stolen property. As Col says, fit a full size wheel/tyre as the spare, fit a plate to stop it being nicked, and then you have a spare that doesn't come with speed / distance restrictions that space savers do. 2012 SDV6 - it's missing a couple of cylinders
Sun Apr 21 2024 6:57am |
