Home > Faults & Fixes > White Smoke on Start Up, Blue/Black under load |
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 79 |
Hi All,
Thu Apr 18 2024 5:38pm |
Thanks Gogey,
Thu Apr 18 2024 9:48pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
The TDV8 has two drain points as there is a separate sump for the turbo drain system. Both should be dealt with during an oil change. Like as not, this wasn't done if they did a tube drain. 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 18 2024 11:21pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 426 |
There’s a vacuum line down by the oil filter housing area that can come off when removing the oil filter housing. It can cause various issues. Might be worth checking if it’s on securely. It’s rather hidden by the intake so may not be noticeable if it gets pulled off. You obviously need to remove the engine cover then look between the front of the oil filter housing and air intake. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Apr 19 2024 5:48am |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 339 |
£21 for oil and filter ?? the cheapest filter you can get on e bay is about £8 and oil £20-30 for 5 litres . so what did they put in ? Always listen to old people or when they die you will live on in ignorance.
Fri Apr 19 2024 8:01am |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 195 |
OP says £21 for oil filter not oil as well. |
Fri Apr 19 2024 8:47am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
they charged me £21.20 for the oil filter
Fri Apr 19 2024 8:49am |
£21.20 was for the filter, looking at LR Spares they are around £10, so a 100% mark up on the parts, which seems in line with other work I have had done. Oil was £118.44, on Amazon is £75. The oil they used is this one, which meets the spec for the engine. I suspect there be better oils available and I will look at getting a change earlier than the mileage requirements, if only because she is doing less than 6k a year. 2010 HSE TdV8 in Stornoway Grey. Powerful Roof Rails and Spare Wheel protector |
Fri Apr 19 2024 9:09am |
Who is doing the servicing? A LR dealership, an independent LR specialist, or a general garage?
Fri Apr 19 2024 10:27am |
It was a general garage that did the service, but I’ll be taking it to the local Indy to investigate what could be wrong with it now, but that will have to wait until after payday.
Fri Apr 19 2024 10:47am |
Deleted duplicate post 2010 HSE TdV8 in Stornoway Grey.
Fri Apr 19 2024 10:48am |
Two plugs:
Fri Apr 19 2024 3:24pm |
Thank you, the videos only showed the plug on the right, as they talked about having a shield up to stop the oil going sideways. 2010 HSE TdV8 in Stornoway Grey.
Fri Apr 19 2024 3:28pm |
Who is producing the videos? 2012 SDV6 - it's missing a couple of cylinders
Fri Apr 19 2024 3:29pm |
