Home > Technical > RRS TDV6 Flexplate
Hoverdroid
RRS TDV6 Flexplate
Hi everyone
Does anyone know the torque setting for the flexplate to crank on the 2.7 tdv6 2007.
if i read correctly the torque converter bolts are 45nm , i just cant find the flex/flywheel bolt setting
Thanks for helping
Post #641186 Mon Apr 15 2024 12:42pm
NoExpert
It’ll probably be in the power train section under flex plate under removal and installation. That’s where it is for my 3.0. It’s a torque and degree rotation spec in a specific sequence. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #641187 Mon Apr 15 2024 4:20pm
Stevepd
Stage 1 - 50nm
Stage 2 - a further 45 degrees
Stage 3 - a further 45 degress
Found this in my downloaded workshop manual that was posted on here some time ago.
Please check if possible to save a faff. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #641191 Mon Apr 15 2024 6:21pm
Stevepd
Have a look at these:
https://www.mediafire.com/folder/bmioajx5v76k7/RR 2006 2.7 TDV6 HSE in Cairns Blue.
Post #641192 Mon Apr 15 2024 7:03pm
