Home > General > Best engine choice for a used RRS? |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 95 |
Later cars typically have updated components, so whatever problems you see with the older cars should have been ironed out to some extent.
Wed Apr 10 2024 8:59am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1135 |
The most reliable engine in the L494 is the V8 Supercharged, followed by the SDV8.
Wed Apr 10 2024 9:01am |
I don't think the V8s were offered for post 2018? 2021 P400e Autobiography |
Wed Apr 10 2024 9:12am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
The SDV6 has been known to have crank failures but there are a lot of SDV6 engines out there - they're in the RRS, Discovery, FFRR and the rate of failure isn't monstrous (albeit awful for those that suffer it).
Wed Apr 10 2024 9:46am |
Yes, but I'd bet most L494 that had it as an option never had that option chosen, so finding one in the second hand market will be trickier. And that will be increasingly so as the years go on as currently (L461) low range is only standard on the petrol versions - the diesel options require it to be fitted as an option even in AB spec. The L461 petrol versions appear to have lower towing limits (3t rather than 3.5t) and slightly less ground clearance, strangely. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Apr 10 2024 9:56am |
4535jacks Member Since: 10 Apr 2024 Location: Haverhill Posts: 10 |
Yes you are probably right but from research it seems the MHEV uses a 48v battery which I hope wouldn't be too expensive. Second hand 48v batteries are going for £700 on ebay.
Would a D300 non-MHEV be a better choice than the SDv6 on the P494? |
Wed Apr 10 2024 10:46am |
The PHEV battery should last you for at least 100K, so for your mileage, that's 10 years. On the other hand, it's possible in the future that fossil fuel prices may be taxed more as the demands for EV vehicles rises, so it's difficult to gauge whether it's more economical in the long term to pay for petrol/diesel or to offset that and buy a larger amount for a new battery in 15 years time. It's all in gut feel and guesswork really. You'll also need to factor in insurance and VED costs over time for the different variants. At the end of the day, however, no one buys a Land Rover as an economical choice - there's a lot more cheaper/more efficient cars out there. Expense is hand-in-hand with the brand and that's what we (as LR owners) fully accept. 2021 P400e Autobiography |
Wed Apr 10 2024 11:55am |
I reckon the plain D300 would be a great choice if you can find one. The engine was well received at the time, as I recall, and it means you don't have the crank or battery issues to worry about. The key will be finding one with low range too. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Apr 10 2024 1:56pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
?si=8lP4Pjjhc1OKs5U8 |
Wed Apr 10 2024 2:33pm |
Yeah, a lot of straight talking from Harry's Garage there.
Wed Apr 10 2024 3:26pm |
