Home > General (L461) > Buzzing noise when vehicle moving from Drivers Door |
rsr Member Since: 10 Aug 2022 Location: Manchester Posts: 30 |
I have something similar started recently, I don't think mine is electric as when I put force on the upper door card it goes away. Very annoying though. |
Tue Apr 09 2024 3:05pm |
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 175 |
I will give it a try. Do you think it’s a vibration then ??? |
Tue Apr 09 2024 6:41pm |
Wed Apr 24 2024 1:44pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 195 |
Mine vibrates also but when I press on the handle it goes away. Only at slow speed and over non smooth roads. |
Thu Apr 25 2024 7:51am |
Hi Rowdie Mine does is at different speeds, it's more noticeable on bumpier roads which is most of the time nowadays! If i press in the area in the image it tends to stop. Cheers |
Thu Apr 25 2024 8:18am |
Thanks RSR |
Thu May 02 2024 12:49pm |
Mine going in to dealer for door card removal to investigate. Something vibrating in there as doesn’t happen with other doors. |
Thu May 02 2024 11:54pm |
if anyone gets any useful info on what their noise is, please could they post it here ? Would be really grateful to have some guidance before it goes in to the dealers.
Wed May 08 2024 10:55am |
