Home > General (L494) > Well I thought it was interesting… |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4853 |
What you mean taking a range rover sport off the tarmac? very few I would think.
Sun Mar 31 2024 10:32pm |
Golan Member Since: 25 Apr 2016 Location: West Sussex Posts: 11 |
I know I know I didn’t mean to it just kinda happened…. |
Sun Mar 31 2024 10:39pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 335 |
I missed the line where you said you locked the diff and just drove out ....done that many times at society weddings with everyone parked in a field at 1 am spinning there wheels.
Mon Apr 01 2024 7:20am |
Don't get me wrong I know that these things in the most part are way more capable than we need them to be and as "Pistnbroke" said it's happened before, I also have a 2004 SWB Mitsubishi Shogun (Stubby) with all terrain tyres that has pulled many, many people out of fields and the odd ditch it even pulled a small coach out of a grass/mud car park once...
Mon Apr 01 2024 9:12am |
The average IQ is 100 which means 50 % of the population have an IQ below 100.......QED..EPLS etc Always listen to old people or when they die you will live on in ignorance.
Mon Apr 01 2024 9:15am |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 120 |
The UK average IQ is as you say,100 but, although it would cost a fortune to calculate it, it has been estimated through batch testing that 70% of the UK pop is above average. 2017 3.0 SDV6 HSE |
Mon Apr 01 2024 9:30am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
He put it in grass mode which will lock the centre diff as necessary. But the centre diff will lock anyway if there is a speed difference between a front and rear wheel.
X5, XC60, some VWs, some Skodas, some Audis are all wheel drive. I've seen old Defenders/Series with chunky tyres struggle on wet grass. If there's no grip then there's no grip. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Apr 01 2024 4:52pm |
I thought I should turn it on as I would’ve felt a complete knob if I didn’t and got stuck… Then to be asked why didn’t you turn on the terrain response.
All of the cars mentioned were all wheel drive as you could see the wheels spinning as they slid off the hill. I know that there’s a difference between all wheel drive and 4 wheel drive, I just thought that they’d do a bit better job of it. And like you say it’s all about grip or the lack there of… nobody had chunky tyres. |
Mon Apr 01 2024 7:17pm |
LR's traction control system is one of the best there is - off road ability on what are basically road tyres is their USP these days. As you nicely demonstrated. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 01 2024 7:24pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 299 |
To get mine to this point I had to go threw a flooded underpass tunnel, not as bad as it has been. Plough threw some deep muddy ruts left by the farms tractors and all the other boys 4x4 trucks. Didn't miss a beat I didn't alter the terrain response just put it in off road height, their faces were a pretty picture as I pulled up in standard road tyres.
Mon Apr 01 2024 7:26pm |
I've yet to get stuck - had 2 or 3 moment where it was touch and go but got out unassisted. The worst was soaking wet grass with that thin layer of slick mud that forms on the surface of the ground around the grass. Like ice. Horrible stuff. It was on the same trip as this:
Mon Apr 01 2024 8:41pm |
Cool photos!
Mon Apr 01 2024 9:27pm |
The AT3 is a good AT. I have run them in the past although I have the Goodyear Wrangler AT Adventurer currently. I think they fit it to the new Defender when "off road" tyres are spec'd from the factory. Not winter rated in LR sizes, annoyingly, but then we haven't had any winter this year so I haven't missed that feature. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 01 2024 9:49pm |
I run at3s on my fullfat and wildpeak on our d3 I'm thinking of a set of wildpeaks on my spare wheels for the sport for the winter stuff when I'm out shooting. |
Mon Apr 01 2024 10:31pm |
