Home > Maintenance & Modifications > Gearbox flush? |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Drop Bodsy a message. I wouldn't call him as he's always on the road and can't look at his diary whilst driving. Be persistent though, 07770 638023. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Mar 27 2024 8:30pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 335 |
Dont flush it can move to places you dont want it . New filter and refill. How do you know its even full ?
Thu Mar 28 2024 8:08am |
Thu Mar 28 2024 8:10am |
tess Member Since: 20 Feb 2020 Location: sheffield Posts: 30 |
Flush or not to flush, well now I dont know what to think. |
Thu Mar 28 2024 12:40pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Most ppl flush these.
Thu Mar 28 2024 1:39pm |
Thanks Ive sent him a text |
Thu Mar 28 2024 2:28pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 391 |
I got mine done at JAS in York. May be a bit too far for you though. |
Thu Mar 28 2024 5:32pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
A drain and refill doesn't replace all of the oil - much of it remains in the torque converter as your Jag nicely demonstrated. Flushing it replaces all of the oil. As for moving crud to unwanted places, it's no different to driving it - the flush machine is just plugged in to the cooler loop as I understand it and draws fluid out and puts fluid back as if it was just going out to the cooler. So crud shouldn't be any worse than otherwise. Mine has been flushed, the filter is, I think, original, and it's got over 150k miles on it and still going. (I hope that hasn't jinxed it!) 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Mar 28 2024 6:34pm |
When doing mine the other week, Bodsy said his old D3 was on 275k having just had oil flushes and the unit still on its original filter. Impressive mileage none the less. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Mar 29 2024 7:55am |
