Home > Maintenance & Modifications > Rubber boot liner
upbeat
United Kingdom 2009 Range Rover Sport SDV6 HSE Java Black
Rubber boot liner
Hi
I have ordered a roll of 3mm flooring rubber with chequered pattern for the boot , so that the mobility scooter will stand on it and i can clean it easily.
I want to attach it to the backs of the rear seats in case i need them to be folded down,so entire area can be cleaned easily.
https://m.media-amazon.com/images/W/AVIF_8...SX425_.jpg
can i drill and tap the floor pan to accept bolts for mobility hoist?
can i attach rubber mat to rear seat backs with self tapping screws and washers? Or should i glue velcro to the seats and rubber mat so they can be removed easily?
Any one else fitted a "autochair " hoist in rear of R/R.
Thanks in advance for any help / insights you can give me!!!
Dave
Post #640622 Sat Mar 23 2024 10:18am
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
These will save you crawling underneath ...Rivit Nuts
Drill , insert . tighten up a bolt fully then you have a threaded hole Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #640634 Sun Mar 24 2024 8:38am
upbeat
What a good idea ......... saves drilling and tapping
will try that
Thanks
Dave
Post #640641 Sun Mar 24 2024 4:32pm
Pistnbroke
Well you cannot drill and tap the boot floor as its only thin steel sheet. they would expect bolts and washers . You will still need to get underneath to be sure you are not drilling into something vital or the spare tyre.!!! Always listen to old people or when they die you will live on in ignorance.
Post #640659 Mon Mar 25 2024 7:47am
GrumpyPenguin
I've used these a lot, but I would not trust them for taking much load, especially through thin material.
Post #640663 Mon Mar 25 2024 9:01am
