Karlp606
Restricted Perfomance issue... | |
So guys Ive had the RP error come on the dash in the last few months sporadically, usually when driving for at least 1 hour at 50mph+, the error does not store as when I turn the engine off (even for a few mins) and on again the error clears and the car drives with normal revs etc.
I put my code reader in and the code given is p006a - Air mass volume correlation, I can clear the code and again the car drives fine.
Today I decided to pop into my local indy garage so they could plug there more expensive code reader in, they said they was a couple of codes with the above and a couple DPF codes, they cleared them and gave the car a test drive.
So my question is could the DPF filter be bringing on the RP error, but usually I would get a DPF nearly full yellow warning and would need to go give the car a blast on the motorway for half hour and this would clear it, could the DPF be now full and not be able to be cleared hence why Im getting a RP error but not a DPF error or warning? Or is RP error basically due to the bad hose or the start of a small manifold crack?
Any help would be appreciated...
Wed Mar 13 2024 4:08pm |
