Home > Technical > Red Suspension light ride height sensor lost contact |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4817 |
I would check the belt. (And maybe the tensioner at the bottom at fault)
Sat Feb 17 2024 11:02am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 122 |
If he bridge the pump relay and the pump works, perhaps you might want to change the relay or at least test that it's working as it should. |
Sat Feb 17 2024 1:53pm |
