Home > Faults & Fixes > Range Rover Sport EGR valves removed engine warning light |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
While I do not think it is possible you got a 3.0 TDV6 made in 2007 - mind you, it's a 2.7 - it seems you need to map the EGR function out of the ECU. Regards etc.,
Thu Feb 01 2024 6:41pm |
Motorman Member Since: 28 Jun 2023 Location: Elgin Posts: 16 |
Hi
Fri Feb 02 2024 10:55am |
James s m Member Since: 16 Nov 2023 Location: Highlands Posts: 10 |
Hi
Fri Feb 02 2024 12:13pm |
Thanks for that
Fri Feb 02 2024 1:38pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 339 |
The information I have from Rimmer Bro (who sell the blank kit) is that 2.7 without the DPF can be blocked off without any problem.
Fri Feb 02 2024 4:24pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Sun Feb 11 2024 12:07am |
