Drivers door wont lock
When I use the remote to lock the car, the drivers door does not lock & I have to try 3-4 more times using the remote to finally lock the car, the battery has neen changed & Ive used my spare key fob. Any solutions?
Thu Jan 25 2024 2:57pm
Karlp606
Could be a dead actuator - prob need a code reader to check if nay error codes show up.
Or spray some wd40/ac90 in the lock mechanism could be a easy fix.
Thu Jan 25 2024 5:15pm
Chances are you need a new lock/latch assembly, plenty of posts on the forum of them failing, front and rears.
