Home > General > RRS 4.2 S/C front driver side is leaning lower |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Would be easier to judge if we knew the how much does he charge for parts and which chunk of the 976 quid is labour. Regards etc.,
Tue Jan 23 2024 11:51am |
wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41 |
Valve block suspension front - £223.13
Tue Jan 23 2024 11:59am |
Valve block suspension front - £223.13 2hr labour - £170 (£85PH) +VAT = £471 Shock absorber front -£230 + 20% VAT bolt - £11.44 nut - £3.79 2hr Labour £170 (£85PH) +VAT = £498.28 |
Tue Jan 23 2024 12:00pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
Is he proposing changing just the airbag or the whole strut? If it's the strut, it really ought to be changed as an axle pair - changing a single damper isn't a great idea, especially if the existing units are pretty old and tired.
Tue Jan 23 2024 12:45pm |
They said the airbag can be changed individually and the valve. There was no mention of strut.
Tue Jan 23 2024 12:57pm |
The £85PH labour seems pretty widely accepted, too. Regards etc.,
Tue Jan 23 2024 5:44pm |
Yeah, the airbag can be done separately. Parts prices appear ok in that basis. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Jan 23 2024 6:14pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 238 |
Used valve blocks on eBay are £15 or so. You can change the seals yourself with a £20 kit.
Fri Feb 02 2024 6:46pm |
PM sent back to you. I’ve done the front valve block at home and it’s not a 2 hour job. It’s more fiddly on a 4.2 due to the radiator, but I think my record was about 35 minutes. This link explains it (duckoby74’s post, not the first few).
Fri Feb 02 2024 10:41pm |
JonnyCJ…thank you so much for all your help mate 🙌🏼 |
Fri Feb 02 2024 11:22pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
If its any help, I've just had 4 shocks (complete units and a new compressor fitted).
Sat Feb 03 2024 7:38am |
Christ
Sat Feb 03 2024 1:05pm |
It’s to calibrate the ride height after changing over components. If you’re not using the car this afternoon or evening, open the bonnet, take off the plastic battery cover and you’ll see the fuse box cover. Pop that off and remove fuse 3. It’s a 5A fuse, top left of the line of fuses, second one down I think from memory.
Sat Feb 03 2024 1:34pm |
Picked up my 4.2 SC this afternoon after having the ride height calibrated and the adaptation software reset following me changing the ride height sensor and PCV valve.
Tue Feb 06 2024 11:22pm |
