Home > My Range Rover Sport > HEATING |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 299 |
Most likley just air locked if you flushed it try putting low pressure water threw it. Just disconnect x1 hose connect low pressure water hose and run it threw. Always worked on my P38 when I had same issue. |
Sun Jan 14 2024 7:39pm |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 |
Not tried this, so disconnect the feed to the matrix and connect the hose to the matrix? Leaving the disconnected pipe open? Or cap it and open the resevoir |
Mon Jan 15 2024 10:08am |
Leave it open the hose connected to the matrix will/should force any air out and after will/should befirced around the engine and come out from the open connector.
Mon Jan 15 2024 4:20pm |
I'll give it a go when the wife gets home with it, i was thinking it was possibly down to the valves by the fbh and on the opposite side if the engine, I'm certainly glad the matrix is clear. Thank you |
Mon Jan 15 2024 7:24pm |
It's worth a try 1st after that the valves is your best bet. Iv not going a diagram of the heater layout but if it's similar to my L322 the heater valve is a common failure point as is the small auxilary pump that pumps yhe water threw the valves and around the heater matrix.
Mon Jan 15 2024 7:43pm |
OK that didn't work, I decided to check the solonoid valve, I opened it up (without removing it as didn't have many tools to hand) and noticed the core wouldn't move much. Do you have any idea how much travel it should have? It spins freely but only moves a millimeter or so up and down. My guess is the o rings are swolen stopping the valve opening.
Mon Jan 15 2024 9:53pm |
The valve should open and close fully if its only moving a mil its not working properly |
Mon Jan 15 2024 10:12pm |
If your valve looks like this
Mon Jan 15 2024 10:14pm |
Yes it's the same as that, I.was just looking at that one myself. I'll get it ordered |
Mon Jan 15 2024 10:17pm |
Nice 1, it's a simple swop out just pop the hoses off the old valve and connect the new one up you won't lose much coolant and can just top up as required. |
Mon Jan 15 2024 10:20pm |
Thanks I'll update by the weekend, hopefully it will be nice and warm in there again |
Mon Jan 15 2024 10:26pm |
So got the new valve, opened it up and checked how much the solonoid moved it was about 10mm, the one on the car moved about 2mm. Removed this and blew through the holes and it was closed on all ports, the new one had one side open. Swapped them and we have heat again. Now to try the fbh, I can hear it but no smoke and only cold air. |
Thu Jan 18 2024 2:46pm |
With the fbh try blasting compressed air into the air intake if you have that option to help get it going if its not run for a long time. After that gap tool to force a start or it's locked out after x amount of failed starts it will need resetting to work again.
Thu Jan 18 2024 3:06pm |
I just primed it and started it with my gap tool, working fine now after the neighbours came running out due to the smoke. Thanks for your help |
Thu Jan 18 2024 3:44pm |
