Home > Faults & Fixes > Possible Gearbox issue, Looking for advise |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Worth reading codes.
Sat Jan 13 2024 4:37pm |
Ken 153 Member Since: 02 Sep 2021 Location: Sheffield Posts: 163 |
Bit of research suggests transfer box, but will get codes tomorrow. |
Sun Jan 14 2024 12:46am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
Wonder if it's something like the T/B input shaft splines worn and slipping under load might give a sort of clicking noise as they ride over each other a bit like a ratchet, I don't think worn splines are unheard off either. only a suggestion, but as said any codes may give a better clue.
Sun Jan 14 2024 2:03am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
Col, worn splines can happen - my old TDV8 suffered from it and when it went in for a new TC, Bristol Transmissions wouldn't do the TC unless they also did the output shaft on the gearbox and input shaft on the TB. Of course, thanks to the way the gearbox is put together, the entire internals have to come out - the output shaft is fitted from the inside.
Sun Jan 14 2024 1:17pm |
