Home > Faults & Fixes > Few little faults to scratch your heads at with me |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
It may be worth checking your battery connections and earth points regarding the electrical issue 2010 RRS, TDV8
Wed Jan 10 2024 8:20pm |
Hodson91 Member Since: 09 Jan 2024 Location: Washington, Tyne and Wear Posts: 26 |
Hello gogsy1956, tyne and wear too I see.
Thu Jan 11 2024 7:00pm |
Aye, wallsend to be exact,, you should be able to upload video just as you do with pics 2010 RRS, TDV8
Thu Jan 11 2024 8:21pm |
Im not sure i know how to do that either, still a newbie
Thu Jan 11 2024 9:21pm |
?si=tjmFYwZOPOytmToV
Thu Jan 11 2024 9:42pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 425 |
Maybe it’s trying to get the music to stop?
Fri Jan 12 2024 5:39am |
I dont blame it, was just crap on the radio.
Fri Jan 12 2024 1:58pm |
Quick update.
Sun Jan 21 2024 11:36am |
Have you checked the wheel bearings? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Jan 21 2024 2:38pm |
Yes, both front wheels bearings have been replaced recently. The osf bearing i didn't personally replace, but it looked new, nsf I have replaced although they werent genuine land rovers so the quality wont be as good but were off LR PARTS so assumed they would of been sufficient.
Sun Jan 21 2024 9:46pm |
Hi all,
Sun Feb 11 2024 1:00am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
So trying to think of rotating things that get warm. You reference it does it in reverse and more apparent when it's warm. So speed can be dismissed I think. Have you considered wheel bearings or the transfer box. The prop shaft hanger bearing? You may be able to find a way of putting your listening ears on the TB. I'm probably wrong as I usually am but I'll suggest it. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Feb 11 2024 8:13am |
There are no right or wrong answers and i thank you for your suggestions. I will be listening in again to front hubs i think. perhaps find a different place to clamp to. And yes i think i will probably put one on TB too
Sun Feb 11 2024 11:29am |
Rear wheel bearings checked? Sounds crazy, but I’ve had what I swore was a front end noise turn out to be the back. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Feb 11 2024 1:10pm |
