Home > Maintenance & Modifications > 60 month service for 5.0l SC Autobiogrpahy |
drb5 Member Since: 12 Jul 2023 Location: Scotland Posts: 20 |
I see the 5 year service includes a "reservoir - expansion"...whats that then? To replace the actual coolant tank?
Wed Dec 27 2023 6:19pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
ARC/ACE fluid reservoir |
Wed Dec 27 2023 6:25pm |
Thanks for the suggestion…what is it? |
Wed Dec 27 2023 7:01pm |
The reservoir for the Dynamic Repsonse/Active Roll Control fluid |
Wed Dec 27 2023 9:11pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
Just out of curiosity DM, but is the D/R filter a integral part of the reservoir now and is the reason the whole reservoir has to be changed?
Wed Dec 27 2023 10:16pm |
Correct
Thu Dec 28 2023 10:18am |
Thanks Mikey. Looking into that now.
Thu Dec 28 2023 7:30pm |
Unless they have changed the schedule on the L494, the Supercharger Belt is every 7 years or 105K mls. the AUX belt is every 10 years or 150k mls. however I would suggest replacing the Aux belt when the S/C belt is done as you have to remove it to replace the S/C belt.
Thu Dec 28 2023 9:17pm |
Brilliant. Thanks very much Col. |
Thu Dec 28 2023 11:00pm |
Ideally should any pulleys be replaced? |
Fri Dec 29 2023 10:38am |
