Home > Technical > Help on suspension calibration gap tool
Ray1979
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Bit of a long one
Come out to my car being wonky one morning
Drove it for a few days hoping it would go back to no didn't move
Brought a jlr sdd wouldn't recalibrate. Went to green oval and he kind of done it with gap tool told me the rear sensors had to b the cause
2 oem ones and nothing. Changed the fronts again oem for peace of mind. Still no change. Done the valve blocks as had them in garage and pump. No change
Tried myself with a brand new gap tool I brought and it's saying file missing after the calibration and won't let me calibrate at all. Any advise would b great as I can't find any good local places to rochester. Or if anyone is local and knows there way around if u can help or solve. Can't use the car as drops to bump stops at present
Post #637962 Sun Dec 10 2023 10:24am
contact PAT @GAP.
I'm sure he will quickly provide advise on the missing file.
There is also a GAP subforum on disco3.co.uk
Post #637971 Sun Dec 10 2023 12:26pm
Ray1979
Thank u I have emailed Patrick so hopefully hear something back in next couple of days I'm just really stumped as everything is new and works as such though live data the cars just seems to have lost the ability to level and files
Post #637973 Sun Dec 10 2023 12:33pm
Ray1979
Pat at gap is at a loss
As passenger rear is reading 280 which is plus 30 on highest gap reading.
He said sensor. So just put another brand new genuine rear sensor on and nope reading I'd still the same. Put oringinal front ones back on to check and there the same. All the other 3 r reading normal and that is the only one reading very high when it's low. I'm at a loss now but my coil kit has turned up so if I can't sort this week I will replace with a full coil suspension kit and have done with it
Post #638068 Wed Dec 13 2023 3:46pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
Have you probed the wiring back to the ECU from the connectors on the height sensors. I just did some work on my control arms and had to replace 3 of the 4 connectors and a section of corroded wire on one connector. 2009 Range Rover Sport Supercharged
Post #638070 Wed Dec 13 2023 4:03pm
Ray1979
Yep belled them from ecu to plug.
All r getting the 4.9v and send the lower voltage along the other wire. And the third I believe is the earth but I belled all 3. I believe there wired up properly as had to take the plug off 3 and resoldered done 1 wire at a time but last owner had already done them so I followed his wiring. Rear passenger is my fault so been concentrating on that one which is what gap said. If I had a wire pinout or colours for plug would b a help I've looked online but can't find a photo of that side rear o a 2009.rrs with all the colour wires etc
Post #638071 Wed Dec 13 2023 4:08pm
rayodunne
https://www.rrsport.co.uk/gallery/albums/u...C1699.tiff
See attached for rear left connector. 2009 Range Rover Sport Supercharged
Post #638072 Wed Dec 13 2023 4:30pm
Ray1979
cheers for that ill double check tomorrow and ill also try run wires direct to ecu from plug and see if that helps.i cant think of anything else to try gap said if its not the wire there at a lose as the module doesnt contain a readable ccf so they cant even rewrite that for me its a set module and u just work off the main.i cant find anything bent,out of place etc,everuone whos tried have come up with a blank so far so wires r the last resort but they all bell accross so i cant see it being them
Post #638073 Wed Dec 13 2023 4:57pm
Ray1979
rayodunne wrote:
https://www.rrsport.co.uk/gallery/albums/userpics/26042/C1699.tiff
bit puzzled as the plugs ive seen show 1 as orange yellow 4 orange red..5 orange black wiring on that link shows different i believe
Post #638074 Wed Dec 13 2023 5:11pm
Ray1979
Is this for a 2009 model plz l320
Post #638079 Wed Dec 13 2023 8:22pm
Ray1979
Mine had pin
1 4.92 volt
4 is 2.0 etc feed height
5 earth
This was oringinal plug as managed to find it but still says out of range a lot. Tried plug behind headlight and wires and there all good with no movement on sensor readings as playing or pulling them. Even at ecu the same. I'm at the stage where I cannot find any other thing wrong with the wiring etc so don't know what else I can do
Post #638089 Thu Dec 14 2023 12:35pm
rayodunne
See below for wiring specific to your vehicle to confirm the colours.
https://www.rrsport.co.uk/gallery/albums/u...202of2.tif
https://www.rrsport.co.uk/gallery/albums/u...201of2.tif
They sell a connector kit.
https://www.lrdirect.com/ymq503220-wire-assy-jumper
More expensive than the Chinese clones I got on Amazon Canada.
Amazon Canada: https://www.amazon.ca/dp/B0CB85DN84?psc=1&...ct_details 2009 Range Rover Sport Supercharged
Post #638091 Thu Dec 14 2023 2:30pm
