Home > General (L494) > Multiple faults ???? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8869 |
I'd check the ABS sensor and wiring on the corner that was worked on. Damage will give you those faults as the system won't know what that wheel is doing. 2012 SDV6 - it's missing a couple of cylinders
Sat Dec 09 2023 4:00pm |
Sgill1982 Member Since: 07 Jul 2023 Location: Kent Posts: 5 |
I have taken the wheel off that was referbished. Disconnected the multi plug and reattached, checked cables all ok.
Sat Dec 09 2023 5:10pm |
Sat Dec 09 2023 5:11pm |
