Home > General (L461) > Deployable Side Steps
Faza13
Anyone had any retrofit deployable side steps fit? If so any recommendations, LR want £3995.
Some 4x4 specialists are quoting £1800 but unsure if it is the right thing to do. ——————————————
2023 - P460e AB, Borasco Grey
2022 - P400 HST, Carpathian Grey
Post #637918 Fri Dec 08 2023 6:39pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
I seem to remember the Queen could afford it . Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #637927 Fri Dec 08 2023 10:39pm
scrumps
Hi,
I have had the JLR deployables on my last three sports (including my new L461).
I thought about aftermarket but fitting at PDI means I get a three year warranty on them plus, they are fully integrated into Pivi-pro which I don’t want third parties mucking around with.
The L461OEM steps are different to the L494 as well, which I’m not sure aftermarket have caught on to.
With the L494, the step brackets become the jacking points, on the L461 they are NOT, there is an “auxiliary jacking point” kit to be fitted with the steps.
Fitting instructions available online explains.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #637935 Sat Dec 09 2023 9:02am
Jjvd21
United States
Re: Deployable Side Steps
https://pegasus4x4.com/product/automatic-e...ver-sport/ 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE
Post #637942 Sat Dec 09 2023 12:55pm
scrumps
Jjvd21,
These are for L494 - see my post above!
Post #637949 Sat Dec 09 2023 4:51pm
Jjvd21
United States
https://pegasus4x4.com/product/automatic-e...rover-new/ 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE
Post #637954 Sat Dec 09 2023 6:22pm
Faza13
scrumps wrote:
Hi,
Scrumps
Thanks, good point about the Pivi-pro.
The quote I had was from Pegasus 4x4, just trying to work out the pro & cons. They do say they are plug and play item. ——————————————
Post #637955 Sat Dec 09 2023 6:57pm
scrumps
Faza,
The L461’s need to be for Pivi-pro AND the brackets are different, they DO NOT include the ability to jack up on the side steps - the latest need additional auxiliary jacking points fitted too.
Look here:- https://accessories-instructions.landrover.com/enuk/L461/G3316861
It’s up to you - your car - but mine are OEM.
Post #638007 Mon Dec 11 2023 6:36pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
No wonder they are expensive dealer for when you follow what is required in that installation guide. Seems that OEM is the best way to go!
Post #638026 Mon Dec 11 2023 11:40pm
scrumps
Hi JP,
That was my conclusion too.
£1200 plus shipping, plus fitting (and no guarantee all the other bits come too) might not be the bargain as first seen.
If fitted at PDI, they come with a three year warranty, as do all PDI fitted LR accessories.
Bad luck on the back order fuel flap - I’m glad I got in early.
Post #638055 Tue Dec 12 2023 7:46pm
Atlanticjon
Northern Ireland
Was looking at the Pegasus steps, but have to concur, the amount of work needed to install, some of it invasive is probably best left to JLR…..
Post #639669 Wed Feb 14 2024 8:38pm
