Home > Technical > Which compressor do I have fitted |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4876 |
The problem is, if it has been changed before it could be either Hitachi or AMK, easiest way is drop the plastic cover and have a look, they have different mounting bracket's so easy to tell, if still original proably Hitachi.
Wed Nov 29 2023 4:57pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 435 |
If you see RVC500010 on the lower cover it is most likely Hitachi. The Hitachi covers won’t fit an AMK unless it’s some knock off unit. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Nov 29 2023 9:40pm |
I think you might find RVC500020 is the upper half, the number on the lower part you can see is RVC500010
Wed Nov 29 2023 10:52pm |
Doh! Fixed it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Nov 30 2023 6:35pm |
AcePratt Member Since: 23 Oct 2023 Location: Leicester Posts: 16 |
Thanks all,
Fri Dec 08 2023 11:19am |
