Home > In Car Electronics > Brake Module Damage |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I don't want to come across as pedantic, but you post above references "the indie I always use"; but you didn't and now it's not gone as expected they're "amateurs" but they were good enough for you to book your car in, and not use the indie.
Tue Nov 28 2023 7:01am |
Raybold7 Member Since: 03 Nov 2013 Location: West Midlands Posts: 17 |
Hi Steve
Tue Nov 28 2023 7:20am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Curious to know what model you have 2010 RRS, TDV8
Thu Nov 30 2023 3:47pm |
2007 3.6 TDV8 HSE
Thu Nov 30 2023 9:39pm |
Can't see why they needed to use a computer to open the calipers,,, they will squeeze back with a rewind tool,,, never had an issuedoing mine manually. As long as the shoes are adjusted correctly again after fitting the new discs,, straightforward. I think they have been trying to use the procedure more suited to the L494 with electronic actuators. 2010 RRS, TDV8
Thu Nov 30 2023 9:57pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Is this the EPB module that has been damaged? That can be controlled from the ODB and if they've incorrectly tried to do something with that then it could it up. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 30 2023 10:12pm |
This is exactly what the indy said. As soon as I called him and relayed what they had said to me he laughed and said a level 1 technician is like a trainee and won't have the knowledge, why did they put him on it? I honestly had no idea what any of it meant until I collected it and took it away. They gave me a printout of error codes saying the module had overheated, and I still have this document. |
Fri Dec 01 2023 7:54pm |
I believe so but I'm not that technically minded; I didn't even know it had one. In fact for years I thought the handbrake was automatic and I never had to pull up the button. Consequently, I had never used my handbrake, even after I was told it wasn't that type of automatic handbrake! What they have said to me is can I get a LR dealer to confirm it is possible to damage the module from the ODB. One forum guy has told me that if they had repeatedly pulled the handbrake up and down and up and down it may have caused the overheating and failure. I'm in no mans land at the minute because in a month my MOT is due so I need it fixing, and I can escalate to a motoring association if they refuse to help or after 8 weeks which will be at MOT time. |
Fri Dec 01 2023 8:00pm |
Would it be possible to use the indie you've mentioned to generate that overheating possibility, or are they fixed on a main dealer?. I think you'd get what you want and in a favourable time period, being mindful of your impending MOT. I just think you will be left wanting with a MD. i hope I'd be wrong........ 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Dec 02 2023 8:09am |
I've given them a quote from my Indy garage to replace it. When I spoke with him at length, he said he doesn't know what they have done to break it but if they have been trying to open it and close it via the ODB that may have caused it. He's fully qualified and certified LR but like all garages, he doesn't have that detailed electronic knowledge, it would need an expert.
Sat Dec 02 2023 12:16pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 750 |
Are they saying that it wasn't working when you dropped it off with them?
Sat Dec 02 2023 2:36pm |
You may be old but you certainly aren't confused!
Sat Dec 02 2023 4:10pm |
