Home > Faults & Fixes > Fluctuating revs |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Like you say Dr Tranny is not a fix only a sticking plaster option, but if you're only keeping it 6 months. Equally something may fail if you are carrying a mechanical fault. Someone else will be along with additional info...... 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Nov 19 2023 8:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
don't need to drain oil
Sun Nov 19 2023 8:32pm |
Hullrrs Member Since: 29 Aug 2023 Location: Hull Yorkshire Posts: 29 |
Thank you
Sun Nov 19 2023 9:36pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
It is very much a sticking plaster remedy and you might find it needs a repeat application depending on how much you drive it and how much the clutch plates are contaminated. But if it's a "6 months and scrap it" car then it would seem a worthwhile thing to try. 2012 SDV6 - it's missing a couple of cylinders
Sun Nov 19 2023 10:08pm |
I had the start of Torque converter trouble - symptom was vibration. My indie added Dr Tranny and that was Jan 2021 and 25,000 miles ago. All still good... 🤞
Mon Nov 20 2023 12:54pm |
Ordered 2 today hopefully will be here this weekend so will give it a go nothing to loose
Mon Nov 20 2023 10:18pm |
Don’t touch the fluid. Wear gloves.
Mon Nov 20 2023 10:53pm |
Wow doesn’t say that on the reviews I will be extra careful thank you |
Wed Nov 22 2023 8:30pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 424 |
Yeah, but probably only in the state of California, where everything causes cancer and needs a prop 65 label on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Nov 22 2023 9:14pm |
Well went through the steps today and tied the dr tranny.
Sat Nov 25 2023 5:09pm |
Robin
Sat Nov 25 2023 10:46pm |
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 20 |
Just to add here, been having the same fluctuating revs which i understand means the TC is on the way out. Added Dr Tranny at the weekend and could literally notice the difference within 1mile...i only do the school run and haven't noticed the revs at all within the first couple of miles. I was another sceptic but it really is a miracle band-aid (plaster for Brits).
Thu Feb 22 2024 11:46pm |
