Home > My Range Rover Sport > Another 1st time RRS owner |
The label should be clearly visible on top of the headlight.
Mon Nov 20 2023 12:44pm |
MHSPORT08 Member Since: 13 Nov 2023 Location: South East Posts: 37 |
Hi Eaters
Tue Nov 21 2023 9:25am |
Sorry, I've not invested in one (yet). Poor dexterity and limited area to work on the car means I end up using my indi for most stuff Robin
Tue Nov 21 2023 9:35am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8851 |
I'm surprised that yours doesn't have the AFS headlights as I thought that it was standard fit on the TDV8. 2012 SDV6 - it's missing a couple of cylinders
Tue Nov 21 2023 10:16am |
I'm no expert having had no experience of a non-AFS RRS but I'm slightly surprised they aren't AFS as I assumed that the TDV8 HSE had them as standard (along with a lot of other toys). I'm sure others on here will advise if they were optional. And the fact that one of your headlights is pointing down would suggest they are AFS otherwise why would it be pointing down? I think another way to check would be to park the car facing a wall with everything off. Turn on headlights. Start the car whilst watching the headlights against the wall. They should do the "dance". If they do they are AFS Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Tue Nov 21 2023 11:43am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
I thought AFS was optional on all models. (thankfully)
Tue Nov 21 2023 6:41pm |
Thanks all, gives me some more options and things to buy......
Tue Nov 21 2023 7:57pm |
Standard on TDV8 and, I think, the SC in the original version RRS. AFS is a good system when it's working, and I miss the headlights from my AFS-equipped original TDV8 - much better than the headlights on my facelift non-AFS SDV6. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Nov 21 2023 8:26pm |
D3 lights are known to be better than D4 lights.
Tue Nov 21 2023 8:30pm |
https://www.ebay.co.uk/itm/364030927032?mk...media=COPY
Tue Nov 21 2023 11:00pm |
Two separate issues. I like AFS for what it does. I found it worked well for me, along with the cornering lights (which, again, were better than the ones on the facelift). I prefer the older lights' beam pattern over the facelift's beam pattern. I'm fairly sure it's because the facelift was designed so that one doesn't need to change the beam shape when going from RHD roads to LHD roads. No doubt a cost saving for LR when building the cars but it meant the lights are simply not as good. Have you had issues with AFS? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Nov 21 2023 11:09pm |
I took a closer look last night and I def don't have AFS
Wed Nov 22 2023 10:37am |
Robin
Wed Nov 22 2023 4:08pm |
AFS can be a when it goes wrong - likely someone said "sod that!" then they saw the price of the AFS units over the none-AFS versions and just stuck standard units in.
Wed Nov 22 2023 8:31pm |
