Home > Maintenance & Modifications > Split tailgate button on keyfob |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
From memory, it's a programmable button and each of the keys can be separately programmed, so are you sure you're using the same key each time? 2012 SDV6 - it's missing a couple of cylinders
Sun Nov 12 2023 4:21pm |
mark8815 Member Since: 12 Nov 2023 Location: West Yorkshire Posts: 22 |
Yes 100% the same key every time. |
Sun Nov 12 2023 4:46pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
ensure car unlocked
Sun Nov 12 2023 4:58pm |
Will go and give that a try now. Thankyou |
Sun Nov 12 2023 5:01pm |
That kind of worked, the buttons on my upper tailgate must be broken, as I’ve managed to get the Land Rover button to unlock the lower tailgate. I think I remember reading that the upper was a known fault. Not to worry, atleast I know now. Thanks for your help |
Sun Nov 12 2023 5:05pm |
I think Ford tailgate buttons fit off eBay (focus?) but you need to use your old connector. (Join wires) |
Sun Nov 12 2023 6:06pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1246 |
If it helps for the handle.
