Home > Maintenance & Modifications > EGR BUTTERFLY & EGR BLANKING ADVICE |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
There is a very specific point in the load mapping (low rpm and moving slowly I expect) where it can cause a flat spot in smoothness or performance.
Mon Oct 16 2023 9:44am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 431 |
I think they got finicky in 2007 when the EMS would throw a check engine light on the dash. 2005/2006 I thought could just be blanked off with no ill effects. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Oct 16 2023 12:50pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 345 |
Just to be clear No Expert are you saying that in a post 2007 you can just blank off the two EGR ports and leave the butterfly to get on with its own life ? No need to remove the butterfly.
Mon Oct 16 2023 4:02pm |
2005/2006 you should be able to blank off no problem.
Mon Oct 16 2023 6:26pm |
Thanks ..I have owned range rovers sine 75 but first one with air bags and more sophisticated ERG so your understanding of my stupidity is appreciated Always listen to old people or when they die you will live on in ignorance.
Mon Oct 16 2023 6:38pm |
Not knowing is far from stupidity. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Oct 16 2023 8:53pm |
jpvd Member Since: 30 Sep 2023 Location: yorkshire Posts: 18 |
thanks for your help all!
Tue Oct 17 2023 7:30pm |
I think you you were to watch the butterfly when turning the ignition off, it will close. Therefore by default it has overrun protection |
Tue Oct 17 2023 7:59pm |
Checked on my 2.7 and its as your photo, Can you just block off the two pipes at the butterfly end and then leave it to get on with it or is more required? I have no problems with my 2009 but dont like the idea of putting exhaust onto the inlet valves . Always listen to old people or when they die you will live on in ignorance.
Mon Oct 23 2023 8:37am |
2007 they started tying the EGRs into the car’s systems. By 2009 they’re fully monitored and certain criteria is expected or you get the check engine light. This is why having them mapped out of the ECU is the recommended way to deal with them. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Oct 23 2023 6:53pm |
Well I bought the kit for pipe removal so we will see ... Always listen to old people or when they die you will live on in ignorance.
Mon Oct 23 2023 6:57pm |
