Home > In Car Electronics > 4.2 SC |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Fridge connector / wiring? |
Tue Sep 19 2023 12:45pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
What are you going to run on permanent live? Not the seat heaters? 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 19 2023 4:36pm |
If you can be bothered to pull out the radio and climate panel, there is a heafty 25A heater ignition supply behind that.
Tue Sep 19 2023 5:31pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 228 |
The heat seaters will be on a permanent live with an in-line fuse to the heated seat switch. Managed to get the cables up into the centre console at the weekend. All nicely braided. |
Tue Oct 31 2023 3:27pm |
Thanks Andy |
Tue Oct 31 2023 3:29pm |
