Home > Maintenance & Modifications > Battery conditioners/ chargers? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4874 |
This is a link to the fitting/wiring instruction for the ctek charger that L/R sell as a over priced option, have to admit they are not the clearest instructions, but does show where to connect to on page 4/6
Sat Sep 23 2023 10:00am |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
This is what the tech guys at Ctek sent me. “I have an 95ah AGM battery listed for your Range Rover, so I would recommend a choice of two chargers for you. Firstly the Ctek MXS 5.0 charger which will charge and maintain batteries from 1.2ah up to 110ah. The second charger would be the MXS 7.0 this will charge and maintain batteries from 14ah up to 150ah, with the MXS 7.0 charger this will safe guard you should you ever wish to charge batteries over 110ah. With both chargers in the box you get a set of traditional crocodile leads along with a set of comfort connectors which are designed to be permanently fitted to your battery allowing you to plug the charger into this lead. Either charger can be used whist the battery is connected in situ and won't hurt the electrics or the battery. “ 2017 5.0 v8 Supercharged Autobiography 2009 2.7 Tdi Fantom custom RRS |
Sat Sep 23 2023 10:02am |
Awesome buddy cheers. 2017 5.0 v8 Supercharged Autobiography 2009 2.7 Tdi Fantom custom RRS |
Sat Sep 23 2023 10:03am |
Personal I went for the MXS 10 which does 10 amps up to 200ah, however I would go for the MXS 7 minimum as it has a 12volt supply facility as well which the MXS 5 does not or never used to should you need it.
Sat Sep 23 2023 10:09am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4815 |
The 7 and 10 are bigger and heavier.
Sat Sep 23 2023 11:12am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 390 |
I have found that the connection of the MXS 5 gets very hot during charging. |
Fri Oct 13 2023 7:53pm |
mike54 Member Since: 19 Dec 2020 Location: NW Posts: 23 |
another vote for ctek, had mine for years and its been dropped, run over, you name it |
Wed Oct 18 2023 10:28am |
