Home > In Car Electronics > Add 7-pin socket next to 13-pin |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Nothing off the shelf
Sun Aug 27 2023 9:53pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 195 |
I know you said you didn’t want to use an adapter, but they are so easy to use and take on/off. Use mine all the time for two different trailers. |
Sun Aug 27 2023 11:10pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Splicing into the cable will cause issues later on, as it's in the right place for water ingress, the adaptors are small and so easy to use, can't ever think of a reason to cut into a perfectly good cable when they are available.
Mon Aug 28 2023 8:43am |
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 |
I would use an adaptor - lessor of the two evils when considering spilcing into existing cable.
Mon Aug 28 2023 12:02pm |
ax_crosser Member Since: 22 May 2023 Location: Hoogstraten Posts: 13 |
Then I will probably take the cable out of the existing 13-pin socket and route it back into the car. Then put a new connector on that end (female side). And then on the male side of that connector I will attach 2 cables: one with 7 cores and one with 13 cores. And those 2 cables will be routed towards the tow hook to the 7-pin socket and 13-pin socket.
Mon Aug 28 2023 6:00pm |
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 36 |
Really just making it too complicated i think
Mon Aug 28 2023 7:51pm |
I have an adapter, I just don't like it. |
Mon Aug 28 2023 8:04pm |
That way you will still have more connections - every connection is a potential future problem. & how are you going to arrange for the vehicle rear fog lights to be disconnected with 2 x sockets ? 2006 RRS 2.7 HSE. |
Mon Aug 28 2023 11:11pm |
I don't see a problem concerning the rear fog lights. That's all working fine now on the 13-pin socket, which will be the starting point for the 7-pin socket.
Wed Aug 30 2023 6:59am |
The problem will be that when using the 7-pin socket the fog light cut out will not work. There are probably ways to overcome this (additional wiring/relays pehaps), but you really are trying to find an over complicated solution to a non-existant problem.
Wed Aug 30 2023 10:46am |
Yeah the fogs lights won't be simple, however it is only an issue if you tow something like a white caravan which will reflect the cars fogs lights badly at night.
Wed Aug 30 2023 12:09pm |
Fit a 13 pin plug to the other trailer!
Thu Aug 31 2023 8:39pm |
If the other trailers would be mine that would probably be the way to go. But they are not, so that is not my call. |
Fri Sep 01 2023 6:50am |
