Home > Wheels & Tyres > pirelli tyres |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
https://www.thetirelab.com/vs/pirelli-scor...ion-verde/
Sun Aug 27 2023 10:05am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4853 |
Looks like the Zero might be a little quieter road noise, and a bit more fuel efficient looking at the ratings, slightly more expensive as well.
Sun Aug 27 2023 10:55am |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
£218.40 each for the pirelli scorpion verde is that a good deal |
Sun Aug 27 2023 1:47pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
The Zero has sound deadening foam stuck on the inside of the tread area, and is the later version of the Scorpion 'family'.
Sun Aug 27 2023 10:31pm |
As the Verde is quite an old specification tyre now, if the Zero AS is a relatively new design I'm inclined to think it will eventually replace the Verde as being what would appear to be a slightly higher spec. tyre anyway, so might be worth going for the Zero, but as I say only a guess.
Mon Aug 28 2023 12:39am |
is this the better option then
Mon Aug 28 2023 7:49am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
The only slight issue I have with the All Season is that it isn't one, really, as it's not also 3MPSF-endorsed. It will be much better than most road tyres in winter conditions, yes, but if you need to go to places where 3MPSF is required, it doesn't help.
Mon Aug 28 2023 9:52am |
If you can still find new Verdes, they should be £100 or so cheaper than the Zeros, and with very little noticeable real life differences, a better buy.
Mon Aug 28 2023 10:02am |
The problem with Pirelli is that they randomly change what tyres they make in various sizes. The ATR and the AT+, for example, used to be available in LR sizes but not any longer - at least in the UK. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 28 2023 5:40pm |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 97 |
What size? Is that fitted? |
Mon Aug 28 2023 6:41pm |
no not fitted size 275/45/21 from tyre leader |
Mon Aug 28 2023 8:03pm |
On occasions in the UK I bought unfitted one's here from Camsikill always found their prices competitive, of course you have to add the fitting charge, but not all places will fit customer supplied either.
Mon Aug 28 2023 9:53pm |
