Home > Off Roading & Green Laning > What size off road tyres and rims (L320) |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
LR did a couple of 19in rims that fit over the TDV8 Brembos. There are a couple of aftermarket 18s around that I think also fit over the Brembos.
Mon Aug 14 2023 3:42pm |
If you're going to be using it for off road work, might be worth looking out for the rare locking rear diff. Not that I've ever missed having one, but I can think of a couple of times when one would have made progress easier and less damaging to the ground. But I've never been stuck because of a non-locking rear diff.
Mon Aug 14 2023 3:51pm |
300bhp/ton Member Since: 23 Apr 2015 Location: UK Posts: 10 |
Is there an easy way to spot the locking rear diff for the RRS? I know on the D3/4 for the UK market you had to spec it on its own, so unless you crawl under the vehicle to take a look, there is no way to know. And most sellers and listings have no idea.
Mon Aug 14 2023 4:34pm |
The only real appeal with the rods is the price as a short term solution. The plugin systems would be my first choice. Will have a look at some tyre options in those sizes. BTW - do you know how the 18" aftermarket rims fit over the brakes? Are they designed bigger or is it just offset allowing it? |
Mon Aug 14 2023 4:36pm |
Put the suspension in off road height and have a look through the left rear wheel arch using a torch. You can see the rear diff. The locking diff has a motor on the top. The Factory HST had the rear locking diff as did the G4. I believe the non-factory HST (a dealer-fitted kit) did not have the rear locker. The rear locker is a very rare thing in UK L320 RRSs so don't get too hung up on it. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Aug 14 2023 11:27pm |
I'm not sure how the 18s fit - whether it's an better shape to the dish or whether it's simply a different offset. The benefit of the 18s if you can fit some is that you can get tyres such as the BFG KO2 rather than the likes of the Grabber AT3. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Aug 14 2023 11:33pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
18's that fit brembos are PD1881 and pretty expensive. HughN found some steel 18's that also fit but can't remember the make - maybe do a search on here. He may also be selling them if not already gone. |
Tue Aug 15 2023 9:20am |
I think Hugh's were Tuffant but don't hold me to it. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 15 2023 10:09am |
