Home > My Range Rover Sport > RRS steering wheel out of alignment. |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
After having my suspension adjusted, my steering wheel would go out of alignment, and despite several adjustments, the problem always came back.
Thu Aug 03 2023 10:33am |
Chromo Member Since: 03 Aug 2023 Location: Valmiera Posts: 2 |
Thanks.
Thu Aug 03 2023 11:15am |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 300 |
You should also set the suspension to "tight tolerance mode " before carrying out and alignment. |
Thu Aug 03 2023 7:41pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
Have you had the steering angle sensor calibrated, it won't change the angle of the steering wheel position but it may cause the warning lights to come on above a few Kph an hour as it's feeding wrong info to the BCM if out of calibration, had a similar issue after having alignment done after fitting new lower arms, which sorted the warning lights, tweaked track rods to re-align steering wheel, screwed one in and one out by exactly same amount (depending which way wheel needs to go) then did the steering sensor again and everything has been spot on since, normal tyre wear, no pulling to one side and brakes as straight as a die without holding steering wheel. Must be nearly nearly years ago, 20K and still spot on.
Thu Aug 03 2023 11:38pm |
Steering angle reset I think is a must after front suspension work. Had this on both the sport and D3 |
Fri Aug 04 2023 10:38pm |
