Home > In Car Electronics > OEM headunit: which one |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Any will do, three are available, two of them will fit your car: single-disc CD player and 6-disc changer. The latter has "465" type marking, if I remember correctly. In general - any headunit that has the green display slightly offset to the right side.
Mon May 22 2023 4:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
You need the unit with the optical fibre connection at the rear.
Mon May 22 2023 6:04pm |
I stand corrected, thanks Andy. Regards etc.,
Mon May 22 2023 6:55pm |
ax_crosser Member Since: 22 May 2023 Location: Hoogstraten Posts: 13 |
Thanks for the info guys! |
Tue May 23 2023 6:13pm |
John R Hickman Member Since: 26 Jan 2023 Location: Dudley Posts: 43 |
CD560 is a single disk player with built in amp and MOST socket for screen. CD565 is 6 disk player without built in amp and uses the MOST to connect to amp and screen. Interestingly while I had my single disk player out I plugged in a CD465 6 disk from a disco and it worked the screen and connected to my phone via blue tooth obviously no sound as I don't have the amp under the seat. So any 6 disk player should work if you have the separate amp. Just be aware though that the disco one has a different fascia shape at the bottom and won't fit without modification even though they look the same. 2008 RRS 2.7 TDV6 S Poverty model |
Wed May 24 2023 11:54pm |
