Home > Tips & Tricks > Which adhesive for interior trim A & C pillars |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 302 |
It's an age old problem that requires an age old glue, I use copydex with good results. I did recover my A pillars with matching fake leather tho.
Wed Apr 12 2023 7:49pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
I think the nature of the material most adhesives will bleed through, I don't know if it would work or not but if it's only on the edges 3M used to do a very thin double side tape for automotive use no thicker than normal sellotape but is extremely strong bonding, I have used it on rubber and plastic and works well, unfortunately although I have some here there is no product code on it.
Thu Apr 13 2023 12:29am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Thanks both for your replies 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Apr 13 2023 7:31am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
The material on the roof of the cabin started to sag on mine. The garage who does all my work and who have got a great reputation for restoring all makes and models said they cannot / would not glue it as there is no adhesive to give it a truly professional finish. He said the only option was to fit new headlining. I guess you could use any glue but the end product might not be as good as we'd like. Barrie.
Thu Apr 13 2023 1:10pm |
Honestly just recover them
Thu Apr 13 2023 1:20pm |
3rr Member Since: 13 Oct 2011 Location: Melbourne Posts: 6 |
Gluestick from newsagent in LR we trust |
Wed Oct 11 2023 10:24am |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 39 |
Use a high temperature contact adhesive.
Wed Oct 11 2023 10:47pm |
