Home > My Range Rover Sport > Black Beauty |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Not sure what you mean by it "being a 494". 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 04 2022 7:37pm |
Yankee Doodle Member Since: 03 Aug 2022 Location: Reading Posts: 17 |
L494 later shape RRS SDV6 HSE Black Edition + |
Thu Aug 04 2022 9:54pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4855 |
If you are referring to your picture that is the L320 "run out" model, or are you referring to the replacement model for the L320?
Thu Aug 04 2022 10:53pm |
That isn't a L494. It's a L320. If you've bought it thinking it's a L494 then you've been scammed hook, line and sinker I'm afraid. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Aug 04 2022 11:23pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1750 |
I think he means that on the 1st August L484's would have been registered.
Fri Aug 05 2022 8:32am |
Perhaps the OP could clarify what he means, although can't see it clearly the reg no. looks to be a 62 plate unless of couse it has had a different plate fitted, if it was a July reg. date would it not be on a 13 plate, as 62 was prior to Feb 28/29 2013.
Fri Aug 05 2022 9:29am |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Have just looked at the reg plate on DVLA and it is attached to an RRS registered 19th July 2013 so it would be one of the last registered L320's. There is no replacement for displacement - W O Bentley
Fri Aug 05 2022 9:39am |
Does it have the rare Black Edition badge? 2023 P440e SE Dynamic on order -cancelled
Fri Aug 05 2022 10:12am |
Got a few of those! Are they rare? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Aug 05 2022 10:53am |
When I bought my Black Edition in 2013, the salesman asked if I wanted the Black Edition badge stuck on.
Fri Aug 05 2022 11:30am |
Ah, yes, that makes more sense. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Aug 05 2022 2:47pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 226 |
My L494 was registered on 6th September 2013 so must be one of the first off the line. RRS HSE Dynamic SDV6 2014
Fri Aug 05 2022 5:13pm |
New registrations are issued from the 1st of March and 1st September not the 1st of August unless they have changed it, look's like the Dealer allocated a registration number to the vehicle several months prior to it being actually registered. I would hazard a guess it remained unsold and someone got a bargain, as by then most people wanted the new model and the dealer gave a good discount being the old model to sell it. The actual build Month/Year of the vehicle will be on the front slam panel under the bonnet.
Fri Aug 05 2022 9:54pm |
I know its an L320, (am on my 12th Land Rover) I said who ever bought it new must have had a bargain, this was registered nearly 4 months after they stopped them, and the L494 was already being sold, this was first registered 19th July 2013 RRS SDV6 HSE Black Edition + Last edited by Yankee Doodle on Sat Aug 27 2022 9:36pm. Edited 1 time in total |
Sat Aug 06 2022 12:20pm |
