Home > Wheels & Tyres > Red diesel ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
I think you may have posted in the wrong section, but shouldn't be a problem, red used to be less refined then white but I think that's changed now with modern engine, now just the same except with a red dye, funnily enough in Ireland it's a green dye or used to be. Just don't get caught on the public roads running it or it could work out expensive. Unless you are using vast amounts personally I think I would stick with white.
Tue Mar 29 2022 12:25am |
Julio Member Since: 24 Jul 2020 Location: Mere Posts: 13 |
Thanks Col, yes defiantly the wrong section. Bit dim me … |
Tue Mar 29 2022 7:56am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
According to this site https://craggsenergy.co.uk/red-diesel-facts/ red diesel has a lower cetane rating and so would need a cetane booster added to the fuel to run in your TDV8.
Tue Mar 29 2022 9:58am |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 |
It will run but tbh its hardly worth it these days |
Tue Mar 29 2022 12:38pm |
DaftRascal Member Since: 08 Nov 2022 Location: Ayrshire Posts: 27 |
Yes! you can and will have no unwanted issues. People have issues running red when they use dirty drums, get it from a less than clean source etc. Water in drums or just dirty whether it's been gear oil etc in the 5 gall drums. |
Wed Nov 09 2022 10:23pm |
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 |
I am afraid getting red Diesel is not as easy as it used to be, our Government have all but banned it , I can use it in my tractor on the fields but not on the road, most places won’t sell it to you. |
Wed Nov 09 2022 10:35pm |
lots of filling stations round here sell
Wed Nov 09 2022 11:50pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
Though I've not had need to buy any this past year (I have a 40gallon drum's worth), all that's required is filling out your name/address/reg of vehicle buying it at the petrol station.
Sun Nov 13 2022 8:23am |
