Home > In Car Electronics > Reverse camera/parking sensor visuals not working |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
I suspect you have 1 faulty sensor, can you download the utlrasonic app on your phone and test them each to see if one is bad? |
Thu Jul 01 2021 3:11pm |
RRS2015Fujiwhite Member Since: 10 Jun 2021 Location: London Posts: 4 |
Ah okay that’s interesting - let me try that out and see where I get. Thank you! |
Thu Jul 01 2021 3:21pm |
I gave the ultra sound detector app a try but no luck unfortunately. It doesn’t seem to detect anything.
Fri Jul 02 2021 10:20am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
what is the correct app to use anyway ? |
Fri Jul 02 2021 10:53am |
I used something called ‘UltraSound Detector’ by Sergio Gudkov |
Fri Jul 02 2021 10:57am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Go into diagnostic mode to see if you get an image from the camera. The camera is transmitting all of the time, selecting reverse only switches the screen to camera rather than switching the camera on. If it doesn’t work in diagnostic mode, you either have a failed camera or a bad co-ax. If there was no power I think you would get a dash warning. 2012 5.0 SC AB
Mon Jul 12 2021 3:14am |
I think any of the ultrasound apps work, I tried a few on the mrs Exeo when diaging my system.
Mon Jul 12 2021 10:58am |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
Ok so camera, different age although I am fitting one with a separate monitor. |
Fri Dec 24 2021 11:25am |
