Home > Maintenance & Modifications > Metallic click from front on drive
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
So far I have had new PRO Bush ARB’s fitted to front. Both top and bottom suspension bushes replaced. Rear lower wishbones and upper rear bushes all replaced - it failed its MOT on the mushes.
SO as per an earlier post my 2007 TDV8 with132,000 miles on it is knock free for the 1st time in its life.
BUT this has allowed the click / clunk noise from the front to be heard more clearly.
If I press the accelerator and then ease off it makes a metallic clunk noise from the front - I think. As an example today I was doing about 35 mph and eased off the accelerator and ‘clunk’!
It does it when I move off in drive - sometimes, and when I move off in reverse!
Diffs? CV? Transfer box? Prop shaft? Drive shafts? A trapped unicorn?
Any ideas would be gratefully received.
UPDATE
So finally we were able to get underneath the beast. Turns out it is the rear propshaft bush. The bearing is literally floating in thin air. New part ordered from AF Bow down Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #611554 Tue Mar 16 2021 1:59pm
Could be the engine mounts - the TDV8 has "active" mounts that help to control its bulk. They look to be a pain to replace. 2012 SDV6 - it's missing a couple of cylinders
Post #611563 Tue Mar 16 2021 5:08pm
1richard1
Not seen it yet but trapped unicorn is good one to start looking for, nothing stupid like anything in glove box or fridge?
Post #611564 Tue Mar 16 2021 5:30pm
Oldandconfused
Don't CV joints make a tick tick noise if lock is applied?
Might be worth taking off the heat shield that covers the rear prop shaft (5/6 nuts from memory) then you can check that the rubber between the shaft and centre carrier hasn't split. If its failed it's possible that the shaft will clunk against the carrier and you will be able to replicate a clunk by hand. Mine had split but not totally failed. If it's the original prop, chances are that the UJ's are notchy.
Post #611574 Tue Mar 16 2021 9:28pm
MartinsTDV8
I’ll have a look at these. Will there by any noticeable play if I try to move the engine about? Previously owned 1999 Disco 2 TD5
Post #611594 Wed Mar 17 2021 11:05am
MartinsTDV8
I’m favouring the CV joints, but the noise doesn’t happen all the time, and seems to happen even when not on full lock.
I had thought about the shaft and the rubber part, so again will look at this. Previously owned 1999 Disco 2 TD5
Post #611595 Wed Mar 17 2021 11:07am
MartinsTDV8
Def not coming from inside the car, and the glove box and fridge are full of sweets, clothes and other such delights.
Bloody unicorns Rolling with laughter Previously owned 1999 Disco 2 TD5
Post #611597 Wed Mar 17 2021 11:08am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
sounds like a driveshaft CV to me. Try a sharp turn while pushing the throttle. if you hear it clicking it's a CV RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #611609 Wed Mar 17 2021 5:00pm
Hodson91
Did you ever get to the bottom of this. My 2010 3.0tdv6 seems to be doing the same.
Regards 2010 RRS, TDV6
Santorini Black / Black Leather Interior
Black Side Steps, Black Autobiography Grill and Side Vents
22" Calibre Satin Black Alloys
ALSO IN THE FLEET
X2 2008 Focus 2.5 Turbo ST225 both approx 330bhp, Electric Orange
2011 Mondeo 2.2 Titanium X Sport Auto, Frozen White
2007 Fiesta ST150 2.0, Silver
2011 Swift Challenger 570SR Caravan
Post #639645 Tue Feb 13 2024 9:33pm
MartinsTDV8
Yes, sorry I had thought I had updated all my posts when I left the site. I no longer have the L320 Big Cry Big Cry Big Cry
It was one of the front drive shaft gaiters that had failed and it had thrown all the grease out.
So I replaced both front driveshafts and the full prop-shaft as the central bearing had disintegrated. Previously owned 1999 Disco 2 TD5
Post #639658 Wed Feb 14 2024 1:26pm
Hodson91
Well thank you for taking the time to reply to me.
I have have a look at both prop shafts
Thank you 2010 RRS, TDV6
ALSO IN THE FLEET
Post #639659 Wed Feb 14 2024 1:57pm
