Home > In Car Electronics > 2010 Facelift wiring diagrams |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8869 |
This is the manual for the 2013 L320. Does that help?
Mon Jan 18 2021 2:40pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4874 |
Try page 8.
Mon Jan 18 2021 4:00pm |
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 |
It does for routing But no wiring diagrams,, |
Mon Jan 18 2021 4:09pm |
It doesn't load mate |
Mon Jan 18 2021 4:13pm |
Not sure why, it certainly does if I click on it myself, try this one.
Mon Jan 18 2021 4:23pm |
Cheers Col, it works, it was my works computer didn't want to play, fine on my phone |
Mon Jan 18 2021 4:37pm |
Probably security setting so you can't view naughty stuff.
Mon Jan 18 2021 4:41pm |
Mon Jan 18 2021 5:12pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 194 |
Hi folks,
Tue May 09 2023 10:48am |
That's a awful lot of diagrams, nearly 300 pages in total for the facelift, although a lot will be the same for both the MY10/11 and later MY12/13. I think the main differences will be the Infotainment circuits/interface. Did you want anything specific?
Tue May 09 2023 11:21pm |
Hi Col, sorry I totally forgot to look at the RRSL320WSM2006.pdf file for the wiring diagrams I'm currently looking into my forward alert sensor issue and wanted to check the diagram prior to physically looking at the RRS.
Wed May 10 2023 6:24am |
If it isn't working by any chance, are you sure it isn't turned off in the set up menu.
Wed May 10 2023 6:39am |
its a strange one, if I activate it in the menu, near enough every trip using crusie control I'll get a warning that there is an issue with the forward sensor and it kills cruise until I cycle the ignition. If I don't activate it and use cruise, I then get the same fault but not on every journey using cruise. The errors are (taken from an older scan):
Wed May 10 2023 6:51am |
I don't know for certain, but I'm inclined to think that one code is causing the other, the radar modules are in a different position between the 05/09 and 10/13 cars, I also think I would be reluctant to assume the earlier vehicle wiring is the same as the later cars but it is a possibility. I assume the module wiring will come under the speed control section of the diagrams but not totally sure, I do have some diagrams here and will have a look to see what I can find.
Wed May 10 2023 7:31am |
