Home > Maintenance & Modifications > ace pipe leak |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Which Union is leaking? 2012 5.0 SC AB
Sun May 03 2020 9:38am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Front of the right tyre |
Sun May 03 2020 9:43am |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 139 |
Replaced mine a while back
Sun May 03 2020 11:01am |
i dont wanna replace the pipes, i mean they are corroded and it will be a ballache when they go. but for now, the only thing thats leaking is the actual junction at the front right of the tyre, does that mean i can just change the junction connector and be on my way? if i whack it open is it going to start spewing a ton of oil everywhere from built up pressure or can it be a 15 min jobo |
Sun May 03 2020 11:40am |
It sounds like you’re referring to the section that changes from steel pipe to rubber pipe. If so, then that’s not available as a separate part from JLR. What you could do is take it to an agricultural supplier and ask them to make up a new section but you may have to remove the part for measurements. 2012 5.0 SC AB
Sun May 03 2020 1:57pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4349 |
There are 4 pipes behind the front right tyre
Sun May 03 2020 3:48pm |
When you buy the pipe set,they all come pre clamped,and with the rubber hose,if the pipe has rusted through ,i'd just swap the lot,it will save you in the long run.Are you doing it yourself ? |
Sun May 03 2020 4:36pm |
ah right, it thought there would be connecting sections. right ill will have to be cause £1600 at the independent ain't happening haha |
Sun May 03 2020 5:18pm |
I replaced my front pipes without taking the body off but had to cut the pipes in to half to fit. Another forum member managed it without cutting them in half but I just didn’t have the space to manage it (2012MY). The pipes I think were £260, oil was about £30, high pressure stainless unions were £8, the body fitting I had to replace (I had to cut it off) and I think that was £8 and I then also put a new filter in a few days later (britpart).
Mon May 04 2020 8:34am |
ta, i'll start scouting the parts, am in Leeds so agricultural stores are hard to come by here i might even dump some some power steering stop leak and top the sucker up on the mean time so the pump doesn't seize. |
Mon May 04 2020 9:15am |
My pipes failed around the rubber body fixing likely due to salt water corrosion under the clamp part. I now wipe the pipes down with oil every so often to try and keep the corrosion down. 2012 5.0 SC AB
Mon May 04 2020 11:53am |
I do wonder how people have such clean pipes since mine literally look like there on deaths door. |
Mon May 04 2020 1:16pm |
if anyones wondering this is the leak
Tue May 05 2020 6:41pm |
Look at the state of the rest of the pipes. All 4 need replacing |
Tue May 05 2020 8:15pm |
