![]() | Home > Maintenance & Modifications > [FAQ] DIY Trailer Light Hookup |
AlanM Member Since: 20 Feb 2007 Location: Victoria BC Posts: 88 ![]() ![]() ![]() |
Note that as in my first post, you cannot just hook up trailer lights to the rear light cluster.
Spurred into action by the idiot above, I got to looking at the problem more intensively. The twit just mentioned hooked up his trailer lights by splicing into the wires just behind the rear lights. Tut, tut this will not do it. LR have already wired up a nice pair of sockets for trailer wires and all you have to do is find these two sockets, determine which terminals operate which rear lights and plug into them.
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
Alan - respect is definetely due |
Alan, you're a marvel with these things. Excellent stuff!! |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 ![]() ![]() ![]() |
Good stuff mate |
Hey - I got another sticky !
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
Has anyone had problems with "flashing" indicators?
xLusi0n Member Since: 12 Jun 2007 Location: Los Angeles Posts: 92 ![]() |
I just saw this thread after I installed my OEM wiring |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Above all check you have a very good earth connection; funny things will happen to indicators, brake lights etc otherwise. |
livefreeordie999 Member Since: 10 Nov 2015 Location: Coleraine Posts: 4 ![]() ![]() ![]() |
Hi, i have just tried this diy approach with using a bulb tester to find out which pins power what. I am using a standard 7 pin socket but i can only get one sidelight to work on trailer board?? Also if i brake the when i am indicating the indicators go off?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Connect the trailer L and R Side lights (black & brown) to the same RRS wire. This is what the factory kit does.
You need a decent load on the trailer indicator. I tried a 5W bulb and the car wouldn't detect it. I find 21W bulbs work best ![]() |
gstuart Member Since: 12 Nov 2017 Location: kent Posts: 3 ![]() ![]() |
Hi
