Home > Australia & New Zealand > Penrite Engine Oil |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4856 |
Anybody have experience of Penrite engine oil in this part of world, impossible to buy either 5w20 or 0w20 Castrol Edge here in NZ, only supply to dealers and they do not want to sell just the oil to you. The Penrite alternatives are readily available off the shelf and just wondered if it was good quality or what others use in their 5.0L S/C as plenty of them down here.
Tue Jan 28 2020 12:42am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
In Aust - Penrite oils are considered overall better quality than Castrol but for your purpose I cannot comment but as long as you have the correct grades I am sure either will be fine.
Tue Jan 28 2020 1:32am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Col,
Tue Jan 28 2020 10:34am |
Thanks all, the slight problem is the owners book says spec. WSS-M2C925-A Sae 5w-20 but that spec. has been discontinued. I think it has been replaced by WSS-M2C945-A 0w-20. The dealer here has been using Castrol Edge Pro. E C5 0w-20 which is fine but just can't buy it here from factors, so just trying to find a good alternative brand to the Castrol only the options here are a little limited. Just that Penrite do seem to do a 5w-20 fully synthetic which meets the spec. etc. according to their web site so probably go for that.
Tue Jan 28 2020 11:05pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Col, Looks like Ford Motorcraft use that spec of oil. Might be worth a call to a dealership
Wed Jan 29 2020 10:28am |
Lindab, have tried using original UK reg. etc. on all main oil supplier web sites i.e Castrol, Shell, Mobil etc. although they all recognise the car only Shell come back with a oil recommendation the rest say something like ring their technical department, even Castrol which was original oil supplier for factory. However it looks like the new spec. for the original 5w20 is WSS-M2C-948-B or can use WSS-M2C945-A which is 0w-20 as long as they meet JLR spec STJLR.51.5122 they are both fine, according to Penrite website their 5W-20 fully synthetic oil meets all these specs. but might just leave it to dealer less hassle, don't really mind putting into dealer but at around £300.00 just for basically a oil and filter change is a bit OTT. Not sure why it has to be so difficult just to obtain the correct oil though.
Thu Jan 30 2020 12:34am |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
I use it I just go for brands that are on discount with the right spec, Purchased 20 litres from Super Cheap last time M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Wed Mar 11 2020 11:02pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
I have researched Penrite oils and for the price you won't go past them. |
Tue Nov 08 2022 7:32pm |
