Home > Wheels & Tyres > 275/55/20 |
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 |
2011 L320 5.0SC, I'm looking at 275/55/20, any idea if they will fit without rubbing? |
Mon Jan 20 2020 9:41am |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 |
This chart will help you , but our RRS have smaller wheel arches than Disco 3-4 and more clerance uses http://johnsonrods.com/johnson_rods_3_004.htm TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool |
Mon Jan 20 2020 6:52pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Below is a pic of my 200 RRS with 275/55R20s.
Tue Jan 21 2020 6:12am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4852 |
Guy, 275/55 x 20 are around 80mm larger diameter then standard wheels with raising the suspension another 10-15mm means you have raised the height of the vehicle somewhere in the region of 45-50mm, has this not effected the stability of the vehicle at all as you have raised the centre of gravity somewhat?
Tue Jan 21 2020 9:01am |
Col,
Tue Jan 21 2020 9:15am |
Thanks all, I will then probably got for the 275/55/20. I will lift her with my IID tool to avoid clearance issues. I would be happy with 255/55/20 but tyre selection here in that size is limited, and I am after more sidewall |
Tue Jan 21 2020 1:10pm |
RainHard Member Since: 07 Sep 2013 Location: Lonehill Posts: 20 |
Cooper Discoverer AT3 XLT 275/55 R20 - beautiful. Rubs (but just a bit). LLAMS fitted . 1st setting is 15mm lift - all sorted (low enough to be stable but high enough to take out the rubbing). Seriously not 100% needed though. |
Wed Mar 08 2023 8:37pm |
