Home > My Range Rover Sport > My new (to me) 2010 RRS TDV8 |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Took about four days to finish the MINI in the end - timing chain and valve stem seals.. that did involve a trip to BMW to pick up a new Vanos sprocket bolt (stretch bolt - couldn't get the chain off without removing the sprocket, despite some people reporting success in doing so, so needed a replacement bolt) and crank pulley bolt (also a stretch bolt - I already had one but, er, made a mistake )
Thu Nov 14 2019 2:48pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4855 |
If you intend keeping the vehicle for some time really worth investing in the Gap Tool, always easy to sell s/h if no longer required.
Fri Nov 15 2019 12:37am |
Yup very true - just a £400 spend I wasn't planning right now Then again .. the "Service Required" message has disappeared now
Fri Nov 15 2019 8:52am |
So .. I invested in a Gap tool, and also had both front wheel bearings replaced with Timken units at the local indy - it's just too damn cold & damp outside to grovel around on the floor changing bearings, and since it won't fit in my garage..
Wed Dec 18 2019 12:39pm |
Nothing much to report since December aside from a couple of new rattles.. the General Grabber AT3 tyres are still excellent - nice compliant ride, not too noisy on the motorway, no big hit in MPG or anything like that.
Mon Mar 16 2020 9:27am |
Nope I still have it! There hasn't been much to add really beyond MOT and a service.. which I should dig out the records for
Tue Mar 02 2021 12:03pm |
Added a few things I'd forgotten and I can't find the receipts for the oil (I bought enough for two services back in 2020) but:
Wed Nov 10 2021 11:39am |
Fingers crossed the new (exchange) PCM from Turners fixes things, because I just paid the bill (mine failed the bench test, so I am hopeful)
Fri Nov 12 2021 10:46am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
I see that between Sept 2020 and Sept 2021 you only had an MOT and service items cost to pay. Got to be happy with a year's ownership for a couple of hundred quid. He says, looking on the bright side of things. 2012 SDV6 - it's missing a couple of cylinders
Fri Nov 12 2021 12:20pm |
Yep, I think it's the standard JLR ownership experience:
Fri Nov 12 2021 12:36pm |
Update now that the car is fixed and running again - brilliant service from Avenger, would absolutely recommend them for anyone local(ish) to Peterborough - after a new low pressure fuel pump, fuel filter, key battery and a repair to the battery-box fuse box:
Fri Dec 24 2021 4:02pm |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 |
Dear god your not having much luck!
Fri Dec 24 2021 4:23pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 424 |
What’s that old saying, “There’s nothing more expensive than a cheap Land Rover”.
Wed Feb 02 2022 7:09pm |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 61 |
Sounds like you have the ac issues fixed now but just so you know I had a 2007 discovery 3 re-gassed at Halfords and a ac health check and it was on a deal for £50 not that long ago |
Tue Feb 08 2022 6:41am |
